Hi
How can there be some scilent mechanical hum from my recordplayer when it´s not on. It´s a Thoréns TD-150 mk1.
I have done all kind of restoring, but not the electrical part.
There is just only one capacitor and one resistor and no transformer.
Please give me some advise.
Ragnwald said:Hi
Can you draw a wiring circuit?
That 5,6K resistor is it paralleled to yellow cap? and both
are connected to the mechanical switch?
Try to change "polarity!!!" of the power cord in the wall socket!
This might help
What i can see, it looks like this.
zoranaudio
He he... your proposal, is like pull the connecting plug out of the wall.
But... i got your point, it´s a leaking 10nF cap?
does it hum when unpluged? An easy check to see if your cartridge is picking up EMI from somewhere else.
cbdb said:does it hum when unpluged? An easy check to see if your cartridge is picking up EMI from somewhere else.
The Man have mechanical hum!!! not hum in the"speakers"
cbdb said:sorry, misunderstood. does it vibrate when playing?
As the man said, it is vibrating when built in automatic switch turned off😀
I also hate any humming in my very silent room when the music stops.
BTW I never turn off my 2KW equipment when full loaded, the lights is light shows!🙂
I think that easiest way to stop this is to remove 10 nf cap, or to put lower value like 2n2 cap. and try.
Without cap will cost some sparking in the switch contacts, and might some short pops in the speakers!!!
cbdb
No problems when playing records.
When playing, the switch on, by-pass the leaking 10nF cap.
Any one, give me proposal of substitute for bouth caps?
And perhaps the resistor should be exchanged to?
Just try replacing the 10 nf cap. If this turntable is older that cap has been on 230v 24/7 for how many years?
cbdb
This player must be some 45 - 50 years old.
Here we have some quality piece to talk about.
But wat type of caps are best useful (modern caps) in these places, as we can see in my schematic?
Or is there a way to make the motorsupply even better, without change of the motor?
Really? I should guess it's from the 70's.Ragnwald said:This player must be some 45 - 50 years old.
If that schematic of yours is correct - with the 10 nF across the switch- the motor WILL hum. 10 nF at 50 Hz is appx. 6.5 kohm - in series with the other 5.6 k. That cap is prob'ly OK.
I cannot see that cap in your photos either....
A cap across the switch in this fashion is typical for a noise killer, prob'ly should be an X1 type filter cap, but in this circuit it causes more trouble than it cures....did you put it there, or is it original?
AuroraB
No, i´ve done nothing to the electrical part.
10nF is the little yellow one in the picture.
X and Y caps, are they not just made for this purpose?
Are there any drawbacks to use them?
X and Y caps are indeed for this purpose......
It's just that 10 nF in series with the 5,6k, or more correctly Xc of 6.4k in series with 5.6k......mmmm
Try to get hold of a new 10nF X-cap - or any other 10 nF 400V for a test....
I just remebered I changed one on my wife's Husquarna sewing machine- gone bad and connected across the pedal. When plugged in, the thing started on ints own after some 10 mins!
- Analog Line Level
- Mechanic hum
