Measuring PCB hole sizes
Reactions: lcsaszar and stv
Just buy one set of mm drill sizes and forget the silly Middle Ages method based on the King´s thumb width size.
LOL A number of dimensions were based on Henry. The inch was standardised to 25.4mm a long time ago now.
1 inch is 25.4 mm, and in my country I get steel scales with the data for inch-metric, and tap drill sizes etched on the back, quite handy.
A metric thread drill size for tapping is dia - pitch. For imperial I uses Zeus tables that has other things in it as well. The range of pitch sizes the metric system did use in the past was crazy but ISO rationalised them not all that many years ago. The imperial pitch system was based on teeth per inch. The numbers used do have advantages when screw cutting them on a lath via gears especially with a screw cutting gearbox.
Depends... is that a nano Etruscan or a micro Macedonian acre?
Philosophically, the measurement system of a culture reflect its world view. They didn't need meters/second when the most they'd do was 20 miles a day with a mule and a cart -on a Roman road. They didn't need clocks either because they didn't work in factories where wages were paid per time and shifts allowed long day production.
I believe their measure of distance were cubits and digits. I've never looked into their area... but I doubt they used area as the square of distance.
