measuring output from my arm/cartridge
Posters,
Can you help me please?
I have built a new arm and would like to measure its output, and see what i might improve.
Helpful posters have suggested a new external soundcard and using REW on my PC. i might do that with their help in the future.
However,
I have used REW for my speakers and was comfortable with that, but might i start using the soundcard in my PC?
PC is microsoft surface book laptop, just a few years old, i have the add on dock with its ports. i have no idea what it has or can do............!
Can i take the output successfully from my Graham Slee reflex C into the PC and REW?
Advice most welcome, thanks
Mike
Which Surface Dock? Most Surface Docks are not going to help, because they don't have any analog inputs. USB, Ethernet, etc. won't do what you need to go from the analog output of the Slee to something that your Surface can digest.
Can you connect an external microphone to your Surface?
Thanks Grufti, Its the most feature full microsoft provide, previous version of this one https://www.microsoft.com/en-gb/p/s...t_web_collection&activetab=pivot:techspecstab
i think you are correct, probably no analog input.
I use UMIK1 with rew through the USB, surely thats an analog input?
This was fortunately well documented and supported and plug and play so it worked easily, even for me!
you may have seen that warrjon has kindly suggested using focusrite scarlett solo soundcard to achieve this but it seems somehow wrong to me that i spend perhaps twice as much on the soundcard than the arm, however i certainly dont want to buy something inexpensive and struggle to make it work, needs to be pretty foolproof for me, which Warrjons suggestion would be.............
all thoughts gratefully received, mike
I bought a Behringer ADC (£20) and it plugs in as USB and with Visual Analyser i have found the measure and experiment process most useful, Mike
