Hey guys, I need advice on how to measure accurately, to match some 10nF caps. This is for a phono stage project.
My Fluke 87 (in relative mode) let me down, or so I think it has. Every day I measure the values go up and down a little -- inconsistent. Is it temperature related or what?
Should I use another method -- the freq. generator with resistance? If so, I need need to purchase one. Anyone try the ones on Amazon ~$90usd? Are they ok?
What to do? Should I better invest in a scope?
thanks!
thanks!
How much? 100pFd? 3pFd?
A good cap meter may be more sensitive than an audio filter used to measure or indeed to EQ.
Even my cheapy Aneng 8009 measures capacitance with a resolution down to 1-10pF.
Are you requiring matched caps to each other, or to an absolute accuracy value (which seems to be your concern)?
Some spectrum software used with soundcards have quite accurate audio frequency generation and identification. If you were using 1% resistors, and had matched them to better than 1%, then you could make up a filter that determines the capacitance knowing R and f. You could also check filter response change for changed temperature of capacitors, and resistors. etc.
thanks!
https://www.amazon.com/KOOKYE-Mega328-Transistor-Tester-Capacitance/dp/B019SXN2M2
Specifications:
Resistance: 0.1 ohm resolution, maximum 50M ohm
Capacitor: 25pf -100,000 uf
Inductors: 0.01mh-20H
PRR,
values change from day to day. Ex: 9.8nF to 10.2nF, using the same testing technique, same room, same caps on the same Fluke 87.
trobbins,
yes.
trobbins,
yes.
Same room temperature and humidity? Have the parts been moved or being held differently? Or did you use clip wires on the probe ends and then not touch the setup other than turn the meter off and on. SO tomorrow, you can carefully turn the meter back on without budging anything else from the day before
You can measure with computer audio out ---10k----+---C1---gnd
+---C2---open
At 2748Hz the voltage at the 10n cap should be 1/2 the sound-card output. (F-3 should be 1591.5Hz)
To compare them ground alternately.
+---C2---open
I built one of these a couple of years ago and have found it very useful for measuring and matching caps accurately:
High-res Cap meter by RomanBlack
Using ARTA Limp I can measure the resonance frequency of an LC circuit -the lowest impedance. With one component known I can easily calculate the other. Very accurate, it allows to measure low values with low DC resistance.
If you want to "match" two caps, instead of relying on a meter, why not just use a bridge? You can do this with a sound card and get very high precision.
I assembled this circuit on a breadboard and seems to work fine.
After that I draw a circuit board and place an order to 5 pcb boards on jlcpcb
DIYAUDIO's own Conrad Hoffman wrote up an easy to use Capacitance Bridge: http://www.conradhoffman.com/cap_bridge.pdf
This is "a phono stage", and probably stereo.
So two steps:
1) 'match' caps and resistors for proper EQ
2) match left and right
He's seeing +/-4% wobble day to day. That's maybe 0.3dB error in RIAA. I remember when that was fantastic but today people like to see 1/4dB.
Is it the meter, or the caps?
What type are the caps?? Some are more stable than others. High-value ceramic is awful. <100pFd ceramic is typically "perfect" (unless a tempco is given).
So two steps:
Is the battery getting low?
I have a fluke 87 as well I will try a cap and check again tomorrow to see if it reads different.
With no cap connected to the leads is there a reading on the meter?
Try to make some real short leads.
The parasitic capacity of the measuring leads of the tester ...
Try to move them away from each other, so that they only approach at the ends of the capacitor to be measured. 😉
I checked 3 capacitors yesterday and today with a 22 year old Fluke 87 and an inexpensive 2 year old LCR meter DM4070.
Friday Saturday
Fluke DM4070 Fluke DM4070
3.05uf 3.05uf 3.05uf 3.05uf actual cap 3.0 uf 250V film
.098uf .099uf .098uf .099 actual cap .082uf film
.00252uf .00222uf .00252uf .00222 actual cap .0022 mica
note the Fluke when reading the .0022uf cap fluctuated between .00245 to .00258 on both days. Short or long leads the Fluke read around 340-360pf with no capacitor and leads open. The DM4070 read 0.00uf with or with out leads.
I dug out the fluke manual and it says readings under .005uf may be noisy and to use short leads or to use the REL feature to subtract the stray reading from current reading.
Friday Saturday
dang looks like software took out the spaces.
should be columns in the above post
DM4070 is $45 on ebay
One of the problems in measuring capacitance is dielectric absorption - the capacitance varies with frequency, and the effect is voltage dependent too. So its usually measured at a standard agreed frequency, depending on the intended use. Unless two measurements are taken at the same frequency (and amplitude) they are not strictly comparable.
And of course self-inductance affects the measured capacitace at higher frequencies too.
Conrad's bridge will measure both C and D.
For measuring the caps for an RIAA network or XO, instead of a "standard" capacitor, use one of the caps and sort through the batch until you get a pretty good match.
His simple design, he makes clear, is just like the GenRad 1608.
It's not the leads. I tried short ones with alligator clips. I left everything unmoved for 5 minutes and made measurements. This Fluke 87 is all over the place. The reading vary from 9.77nF to 10.1nF for the same Wima KFP caps. I think it's the meter. So I will try one of the budget cap meters. This kit looks good (High-res Cap meter by RomanBlack)
High Resolution Capacitance Meter DIY Kit ver.3 (Advanced Edition) with LCD RH Electronics
- Design & Build
- Equipment & Tools
- Measuring low capacitance accurately
