Measuring harmonic distortion with the ECM8000
ente - thanks for that chart. It is exactly what I was looking for.
Jmmlc - agh! I should have read the entire article when ente posted the link. Great info, thanks.
Svante - 1% is -40db.. ouch
This thread has been very informative.
According to the chart on page 15 of the Arta Application note, the ECM8000 will have .30% (about -50db) distortion at 300hz and 111db. The sloping chart indicates it could be less at lower spl levels.
The chart ente posted shows slightly higher distortion than the Arta Application note, but it's at 200hz instead of 300hz. At this lower frequency it measures .25% (about -52db) at 105db. It looks like distortion starts to level off around .15% (about -56db) below 100db.
I took my harmonic distortion measurements of the XG18 at 85db, and it still looks they are around the same level as the ECM8000 would be. Maybe I am measuring the distortion of the microphone only... meh, I don't know. Maybe I should quit worrying about things happening below -60db, since my ears will not be able to distinguish it.
Dan
I'd say for most DIY'ers you could just as well skip the calibration curve if it isn't from your own mic. Just not trust it above 20 kHz.
I have less deviation than the calibration curve above. See my measurements below:
Please disregard deviation below 30 Hz. This is caused by poor S/N (did not bother to close both doors to the anechoic chamber...).
I have not done any distortion measurements with the ECM8000, so I can't comment on that.
Bjorn
bidland - thanks for posting that response curve. I think the calibration file I've been using may be slightly overcompensating. I found the manufacturers response curve, loaded it up in SPLTrace, and got the following.
Vikash - can that same mod be applied to the ECM8000?
Link to SPLTrace ecm8000-Manuf.SPLTrace.mic
Dan
Svante said:
So, the measurements seem to suggest in the order of magitude a percent of distortion or so at 120 dB SPL.
That is not very little. 🙂
Run a 200hz test tone at 120dB and see if the mic at just over 1% THD or the driver has more distortion 😉 Comparatively it is very little which was my point all along.
The issue of THD contributed by the ECM8000 being a factor that would call distortion measurements into question is mute, there is an error margin but if your sensible about this then you realise that its all relative. If you take issue with that then you better email Zaph and John K to tell them they're misinforming the DIY community with their efforts.
My point is that the data captured by the ECM8000 is more than good enough to be informative.
Well, ok, let's agree on the numbers, the distortion is about 1% at 120 dB. Really, that is all the information needed.
As you say, if this is much or little depends on the context. For measurements at 1 m distance, it sure is less than most speakers produce. For close field measurement, I'm not so sure, and for measurements inside the box (which can be a great method for FR measurements) it is definitely too much.
Ok?
I use Behringer Euro rack UB802 mixer that has phantom power, line in and out, 2 mic in, monitor out, phones out.... and all that for around $ 50.00.
You most likely wouldn't need all these extras, but just preamp and phantom power will serve it's purpose.
