I'm looking to build a small transmitter (using only"useless" tv tubes) for broadcasting onto antique radios. My question: What equipment would I use to get an accurate measurement of the AC voltage (rms) generated at the local oscillator (Armstrong type) at 8.200 MHZ? I connected a 560 pf cap to the plate and to a 47k resistor and got readings on the order of a few millivolts with my multimeter. Do you this is just typical?
6f6 said:My question: What equipment would I use to get an accurate measurement of the AC voltage (rms) generated at the local oscillator (Armstrong type) at 8.200 MHZ?
An o'scope, and for accuarcy, make sure the BW is 20MHz or better.
