I have a 8 channel active setup. When I want to take a sweep in Rew I only have the option to playback one channel at a time. output is 1 to 8 but I want to measure the response on all of them.
I use Audiolense to create correction files. Playback in Roon.
do you have a DAC in your system? input your laptop into the DAC instead of the DSP. that will allow you to do a full sweep.
