MDD technology in multi-way systems
Hello to all
in the "MDD Multi Delays Diffraction (Multi TL, omnidirectional, single drive, ...)" tread I inserted a post on the MDDXH135 prototype. It has an omnidirectional MDDFL front loading for high frequencies, very simple to make, and an MDDBL rear loading for low frequencies that requires more work. I will continue to insert the new posts in the "MDD Multi Delays Diffraction (Multi TL, omnidirectional, single drive, ...)" tread.
Acoustic loading systems can also be used in 2- and 3-way systems.
The MDDFL front loading makes omnidirectional the emission at medium and high frequencies for any electrodynamic speaker.
MDDBL rear loading can be applied to the woofer. It has 12 transmission lines with 12 resonant frequencies distributed over an octave, effectively making its behavior neutral in the frequency domain. See neutral cabinet page.
For those who want more information on the MDD technology that led me to develop these acoustic loads, I recommend the acoustic page.
Right now I don't have the material or the skills to make quality Multi-Way systems. I am available to give more information about my prototypes for experiments in Multi-Way systems.
Thanks for your attention
Claudio
MDD3FE25 an MDD project with the 3FE25 driver
https://www.diyaudio.com/forums/pla...nidirectional-single-drive-8.html#post6170069
other documentation is published at MDD3FE25.
