MD60N-6 SB ACOUSTICS: need Thiele-Small-Parameter, revision version?
Thanks Shadowplay62 ! I don't want to take advantage of your kindness and patience now, but could you help me with the curves of the SICA 12 PFS 4 8Ω? Then I promise I'll start studying VituixCad2 🙂
As for the TW and the MD, I loaded the curves into Boxsim and put QMS QES and VAS =0,1L taken from another speaker. It should work correct, right?
BTW what do you think of the SICA12 PFS 4 (reflex 60lt 45Hz) + SATORI MD60 + SICA 110 cut at 6/12 db at 1500 and 6500 Hz?
