MCM 55-2195 mystery
8" Die–Cast Poly Cone Woofer 8ohm.
Thiele–Small paramaters:
•Fs 36Hz •Qts 0.386 •Qes 0.485
•Qms 1.889 •Vas (liters) 51.2 •Sd 0.0214m2
•Re 6.8W •Zo 33.3W •Cms 0.0008m/N •BL 8.7 •Mms
23.6 •Xmax 5.3mm Physical characteristics:
•Power capacity (RMS/peak) 85W/120W •Frequency
response 35Hz~6KHz •SPL (1W/1M) 89dB •Voice
coil 1.4" •Magnet weight 30 oz. •Magnet diameter
4.7" •Overall frame dimensions 8.27" x 8.27" •Baffle
hole diameter 7.13" •Mounting hole centers
diameter 8.5" •Depth 4.04"
Order # (1–3) (4–up)
55-2195 $32.95 $27.94
rgds, sreten.
FYI:
b:)
