I have a McIntosh MX150 AV-processor/preamp with a problem.
When power plugged-in, BOOT for about 10sec and MCINTOSH MX150 on display.
No selections or actions possible, no HDMI output for monitoring or menu display. Standby/On is flashing.
When power plugged-in while holding the test button, I have a X-mas tree. All logos or symbols light up as a running light, all switches and knobs give a change in the display.
Please help me with your well known good advice.
Thank you,
Philippe
Thank you,
Philippe
Hallo Philippe,
Ik heb net hetzelfde probleem met mijn toestel. Echter na veelvuldig proberen start hij af en toe nog wel eens op maar meestal blijft hij staan op "McIntosh MX 150" en gaat hij niet door. De rode led boven de rode on/off toets knippert en je kan het toestel ook niet uit zetten. Ben genoodzaakt de stekker uit de stroom te halen.
Heb al zelfs het moederbord eruit gehaald en gereset, geen resultaat!
T
Hello Philippe,
I just have the same problem with my device. However, after many attempts, it occasionally starts up, but usually it remains at "McIntosh MX 150" and does not continue. The red LED above the red on/off button flashes and you cannot turn the device off. I have to unplug the power cord.
I've even taken the motherboard out and reset it, no luck!
Please post in English
Hugo
Moderation team
Translation:Hallo Philippe,
Hello Philippe,
Hugo
Moderation team
