MC GOLD
Fellows,
Both of you have a point here.
The comparative weight ratio is indeed not the factor.
The choice of gold as opposed to silver was one of crystaline structure.
Also it was reported to sound "better".
The flexibility turned out to be more of a problem than a blessing.
The first batches supplied to a number of manufacturers were so pure (OFAU,9 nines) that it just broke when winding the coils.
So,iso sacrificing this purity we went for a higher tensile strength insulator (Kapton) and asked the coil manufacturers to hand wind the coils.
This solved the warranty issue but it was a royal PITA.
All of you will also have noticed the substantially lower output of these MC's which again makes them very susceptible to lose resolution of low level detail if not matched carefully to the headamp (be that transformer or active device).
A little trick to enhance RFI rejection on such low voltage carriers is to polarize the shielding of the interconnect cable with a battery.
"don't breathe too hard at the greasshopper, you might rip off the wiring"
Oh,yes.Any displacement of the coil windings will upset their operating field.Those windings should have been fixed to the coil after winding was finished.
Or not be exposed to the elements at all.
I think that what they do now having learned the hard way.
Those of you curious to see the innards of a high-tech catridge can take a look at:
http://users.pandora.be/jallaerts/
Thks for your input,
