I want to replace woofer driver on my MBL 311C4 speaker, but could not identify what the driver it is.
It is a 5 inch mid bass driver, dual voice coil, probably made by Dynaudio, Mid driver is Dynaudio D52AF and tweeter is Dynaudio D21/2, so I think that.
Thanks a lot.
Thanks a lot.
It`s unlikely you will get them new.
I don`t know if I would want them used.
But here`s a replacement which should work:
MONACOR - SPH-135TC
The crossover probably needs some tweaking though.
MONACOR - SPH-135TC
Thank you GlobalPlayer, I try identify the original driver first, used one but in working condition is ok.
But noted your information for future use if really cannot find original one.
My woofer also be used in other MBL speaker model MBL 300C or MBL 321. Hopefully someone know and share information.
Thank you.
Thank you.
Update status a bit. After could not find original Focal, I could managed to repair the woofer, luckily just a minor issue with coil alignment.
However, I finally decided to adding more woofer to my bookshelf to extend its LF. Really love the sound now.
- MBL 311C4 woofer replacement - Help to identify which woofer to use
