May I have your ideas for this opamp>LCR>opamp>tube>output transformer phono stage
Hi
May I have your opinion please. Thank you.
http://www.youtube.com/v/T4wptG4eCTs
http://www.youtube.com/v/xCabYdRFaEo
http://www.youtube.com/v/noZEZDnT0gE
Hi
Please see schematic. Thanks.
Why not add a 10k volume control in front of the tube section and use it as a line preamp to drive your power amp directly. In other words, have the IC section as a stand alone phono stage and the tube section as a line stage. Looks like they are physically separated in your project anyway. The YouTube videos sound nice but where are the shots showing the preamp? Have fun with your project.
I have some questions: what is the LCR component between the IC stages? What is the purpose of the tube and the output transformer? (Or what is the purpose of the IC stages, in other words why not full tube or full IC design?)
LCR is a RIAA equalization passive network consists of L:inductor C:capacitor and R:resistor. Opamp has some advantages and vacuum tube also has some advantages I would like to get it all so I use both.
I have already had CD player + pre amp + power amp system and I am new at record playing that is the reason why I built this phono stage. This phono stage consists of both IC and tube section working all together and because of the tube section used to be my headphone amp so you can see them like they are physically separated but it will be finished in one piece box with another piece of power supply box. The sound of YouTube videos was recorded directly from this phono stage to mic port of notebook computer via mini to mini cable (I used a notebook computer to record these videos). Thank you.
I am preparing for easily portable version. It will be delivered to my friend's houses for seriously audition test. ^ ^
Looks good! Good luck with the audition.
How are things going with te flood by the way?
Thank you.
Please see through the link Bangkok Underwater - Alan Taylor - In Focus - The Atlantic
I would like to add one more YouTube video. ^ ^
Don't Know Why Seven Years Norah Jones KENWOOD KD 600 SME 3009 S2 improved clearaudio aurum beta S LME49710 LCR 5687 phono - YouTube
Sound of the phono in below picture was directly recorded by notebook computer.
The 2 boxes version phono preamp has been finished. ^ ^
May I know what should I do if I would like to hear no hum (deadly quiet) while fully up volume at preamp. Kindly advise please... Thank you
What I have done
- power transformer has been seperated
- star ground
- opamp circuit has been shielded with small closed aluminium box
- vacuum tube has been shielded
- shielded signal cable has been used
What I have done
- star ground
Do you have AC heating of the tube?
No, I don't.
It is a floating DC.
- Analogue Source
- May I have your ideas for this opamp>LCR>opamp>tube>output transformer phono stage
