Having a little trouble with my first diy project. I've bought the maxamp20 with 3,5mm jack input and planned on using a minidsp 2x4 to act as a crossover.
Forgive me if this is a silly question, but does the signal remain in stereo after going through a splitter cable and into the 3,5mm jack to come out the maxamp in the respective L and R outputs? Or does the splitter cable/ 3,5mm jack turn the signal back into mono?
Thank you
Thank you
Funkster -
If you're talking about a splitter that reduces two RCA female plugs to one 3.5mm stereo male - like this:
Then the stereo signal is intact - the right channel hot goes to the 'tip' (outer conductor), the left channel hot to the 'ring' (middle conductor), and both channel grounds are tied together and connect to the 'barrel' (inner conductor) of the 3.5mm plug.
I'm working from dim memory, but I **think** I've got it right....
Cheers
Jim
Cheers
Jim
I mean a splitter from two RCA male plugs into a 3,5mm stereo but I don't think that makes a difference.
Thank you for clearing things up for me
