Max thunder 4160
Someone tried to repair this amp before.I found the PS gate resistor open.After replacing them amp powers up but the 494 is getting hot.I see 3.6 ohm from the first and last pad of the PS FETs.Is that normal for this amp?
Any suggestions?
I don't remember seeing any other of this type of amp (with a driver transformer) that drove it directly from the 494 but if that what you have, it could be the reason that the IC is heating up.
It's not driven from pin 12. That's the supply pin for the IC logic. It's driven from 8/11 or 9/10.
I didn't see it earlier but I wanted a 10uS timebase and you posted a 5uS. That would make the frequency higher than I'd expect. That could be the cause of the heating with the other FETs.
Calculate the oscillation frequency from the installed components to see if it's what it should be.
