So
Ok i am a bit slow, is there some calculation given an amount of watts and sensitivty that tells you a theoretical max spl? For example I have SoundStream Tarantual series T4-15 with a 91db at 1 watt at 1 meter, and will be pushing those with a 2000 watt rm Picasso PCA200D amp also from soundstream. Without sitting there figuring out exponents (2, 4, 8, 16, 32, 64, 128,256,512,1024,2048) i know this because of computer programming lol. By your calculations i would only hit around 124db. I think that is right, 11 double in power, 3db gain for a total gain of 33db added to a sensitivity of 91db = 124. However on 1000 watts and 2 10" in a ported box i hit 138.9 on a term lab meter (official meter of db drags) and the box was to small for the speakers, and the starting sensitivity was only 82. Something just don't add up, with 2 15"'s seeing 2000 watts i should be in the 145-150 on the term-lab meters.
