Okay, some pics.
General layout:
Power will be on left, in/out on the right. Sides and frint edge of the base plate will be trimmed down and squared up.
Grounding arrangement:
If I experience and ground loop issues etc., I can simplt unplug it.
Groove in heatsink (shape is from profile of tablesaw blade):
Arial view showing top HS threaded holes:
Note the floating volume pot. All the currently messy wiring will be replaced and cleaned up.
General layout:
awashi said:The 25V/18V CT TRANSFORMER buyout for $5 i guess?
The big online shops i know around here only sell transformers with 18V and 30V secondaries for some reason, no 24V ones.
Might have to try parts express
Its the $7.00 48VCT. And I can confirm it works very well for Mauro's amp. Mine has 30+ hours on it.
Lab tests successful.
I got my amp back from the lab with a clean bill of health. No oscillation, and what has been described to me as incredible low THD. .06% average at 10V from 20hz to 20Khz. SNR was 97db!!! Thats the best any amp of mine has ever measured.
No oscillation at all.
Thanks for the design Mauro. It am fully confident my amp is a success!
Cheers!
Russ
Cheers!
Russ
awashi said:Gathering stuff to order along with it to get the minimum $50.
Edit: Oops forgot they prolly have 110v primaries
Could try two 25V CTs?
A would never use a 110 rated trafo on 220. It's generally a bad idea.
alpha pots
Brian, and anyone else using alpha pots for this amp may want to look at this:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=61645
Cheers!
Russ
Cheers!
Russ
Joined 2003
What seems to be the parts have arrived today. I have to go to the post office tomorrow and pick them up. So from the 22nd to today is one week for shipping to Saskatchewan Canada, and I owe $10.12 for duties/taxes. Thanks again Brian for the parts GP.BrianDonegan said:If your parts kit has arrived, could you update the WIKI? I want to be sure everyone receives their kits, and am alos curious as to how well the various shipping methods are working outside the US.
I recieved a delivery today from Apex Jr. Included were Nichicon 12,000uf 35V caps that snap right into the boards.
Get this: 2/$1. If you haven't gotten your caps, or need more, consider them.
Now I have no excuses. The parts are here. The wife is away on Sunday. The kitchen table is MINE! The aroma of solder will fill the air.
Calmart, I haven't forgotten your question for a better understanding of the AXP caps article. I'll post a summary on Sunday, as well.
bg40403 said:I recieved a delivery today from Apex Jr. Included were Nichicon 12,000uf 35V caps that snap right into the boards.
Hey Ed!
Glad to hear from you. Thanks so much for the care package. I will put that stuff to good use.
Cheers! And happy solder sniffing.
Russ
- Group Buys
- Mauro Penasa's INV GC/REF GC group buy.
