Matts RH84 build
Building an RH84 revision 2 with 5r4gy rectifier and Sony Tamradio power & Output transformers. The case is an old suite case \ portable record player - re vamped with many hours of sanding & spraying etc.
Problems so far, i noticed I have wired my 200uf cap as the first cap rather than the 47uf one. I will change this next its an easy fix.
The two 100uf 100v Kemet peg124 Caps that i bought are way off in value, one measures 98uf the other 128uf. Iam not going to use them. Probably order some rubycons.
I sure am running out of space too.
Thanks both yep used the kemets after your advice. Just have to wire B+ now then inputs and outputs. I finished the other channel today and realise when doing this that I had grounded the wrong pin on the LM317 so i sorted that on both channels too.
I think that I will buy a variac, i keep going through the circuit but am not 100% confident that i havent made a mistake. I have found a few silly ones along the way. Are there any voltages / test points published any where for the circuit? My 1st P2P build 🙂 Thanks Matt
Trying to check out my wiring for those sony output trans. I downloaded the tc500 schematic. It looks like red (p) goes to the plate and brown (b) goes to B+ . Not sure about the black and white wires though can any one confirm which should go to red and which black please? If not I will wire black to black and check for screeching or howling.
Those outputs are marked on the bobbin. B+ is brown and plate is red. HTH...
Hi thanks for rhe reply. Yes the schematic confirmed that my wiring was correct for B+ and plate, but I couldnt underdstand the speaker post wiring for the 8 ohm tap. Does the white wire go to the red speaker post and black one to the black speaker post. If i get this wrong the amp oscilate.
This hasnt gone well today. Voltage from transformer is 325v x 2 (650v). I have an unloaded b+ of 397v at the 200uf cspacitor + terminal.
I thought this would decrease when I connected the amplifier circuits (load). But it didn't. I have conected the speakers and a source so that they are not un loaded.
I am using a current dim bulb device and variac. If i crank the variac up slowly at about 200v of b+ i get crackles on the speakers. But the bulb starts to glow a bit this gets brighter as I increase voltage on the variac.
Something else that i have noticed the 12at7 heaters are not coming on. This is odd as I get 6v on the socket pins when the tube isnt in. I also disconnected the b+ from the amp and put ane el84 in the same socket as they use the same heater pins. The heaters on the el84 work fine. The rectifier is working but b+ is high is it not at 400v. But the 12at 7 works fine in my other amp. I dont know where to start to be honest. The wiring on the rectifier and power supply circuit look fine to me. And irs a pretty simple circuit. Please can someone help if possible.
the lm317'swill affect the loading on the tube . 37 volts seems high for an el84. the tube is running near cutoff. (tube turned off). voltage should be about 22 volts. Can you post an as built schematic? I can't make out the wiring on the el84's
Please attach a complete and accurate schematic of your amplifier.
No schematic, an incomplete schematic, or an in-accurate schematic is the same as:
Blindfolding an archer, and asking him to hit the bullseye in the target.
Just my opinions.
PRR 6A3 In one of the pics you can see that he is using only pins 4 & 5 for the 12at7 heater
Hi yes all. I know that I am definately using just pins 4 and 5 for the heaters. I know I have done this no question, and also I know that I should not have done this. Thanks for pointing it out Mike. I should have known better to be honest. Didn't set about correcting it tonight as I had already sunk my 1st beer, one for tomorrow morning.
Hi thanks for the further suggestions.
I have tripple checked lm317 as I did find this confusing, and I am sure I have it right. Pin 1 to ground and the the side of r7 (27r) that needs to be grounded. pin 2 other side of r7 (27r), pin 3 goes to pin 3 of el84 (cathode).
I have rewired 12at7 one side is not crackling now but quiet music and slightly destorted.
Please excuse my crude drawings I have gone through my circuit and sketched it out . One side of amp and the power circuit.
