Matti Otala - An Amplifier Milestone. Dead or Alive
Yes, Bob, as far as MY circuits go, that are NOT class A. Still, with preamps, I have found that no Global feedback is best. That might hold for power amps, but I personally have taken a commercial design far enough to make a successful power amp completely open loop. Charles Hansen HAS done so, and he has a Class A rating, just like me, AND one former JC-1 customer turned in his super JC-1's (Bob Crump's personal amps) for the new AYRE power amp. This tells me that I have to try a zero feedback, just to be sure.
No, I will NOT be boxed into a compromised or conflicted position on this, by anyone.
Matti Otala continued to maintain that a 20KHz open loop bandwidth was a very good thing. I think that it is PIM distortion reduction that is intrinsic with high open loop bandwidth, all else being equal, is the reason. Where have you been? Has this not been put forth at least 100 times?
janneman said:
But Dimitri, that is only when you drive the input with a signal faster than the amps' slew rate. It's not difficult to upset an audioamp by driving it with sub-microsecond rise times, but why would you do that?
That's the whole discussion isn't it: if you have an 100W amp (40V peak) that can slew that 40V in 1uS, it will never slew-rate limit at any reasonable audio input. If you want belt and suspenders, make it a 100V/uS amp and put a 200kHz input low-pass in front of it. Done. What's next.
Jan, let me cite myself:
Wavebourn said:
Sure, if feedback loop does not meet the criterion of 180 degrees and more than unity gain on any frequency. That means, all stages must have different frequency characteristics. But the faster stage before the slower one will definitely clip first starting from some signal level starting from some frequency. Since they are all in the loop it does not matter is it an input stage, or is it an output stage. The obvious solution is to use a diode clipper before the slowest stage, even if it will be engaged with higher frequencies only. I don't know if a frequency dependent clipper as a countermeasure against severe distortions caused by slew rate limiting patented or not, but if it is not you may assume it in Public Domain as soon as I click the button and submit this post.
It does not matter which stage is slower, but pushed out-of-limits will be the stage that precedes the slowest one. If it is an input stage, it will be the weakest chain, especially when points for closing the loop and for the input signal are different. In such case if an input signal is not over a slew rate yet, clipping would definitely make that speed causing still the same effect. So, an inverting connection, where an input signal goes to the point inside of the feedback loop, is the way to eliminate distortions caused by limited slew rate, but in case when the 1'st stage is the weakest point in chain, especially if to use "standard" for today Miller compensation in the 2'nd stage.
But no matter how you try, you can't avoid increase of distortions caused by slew rate limit absolutely, since for the stability you need to have stages with different frequency characteristic. That means, if to go round following feedback path you will always find the weakest part of the chain: the stage that precedes the slowest one.
What is possible, to shift poles way above frequency band, and use input filter to avoid overdrive by errors.
What we are working on, at this time. is bandwidth differences vs PIM. Bob didn't find much, but we are still hopeful. I don't understand why I have to answer the same questions and challenges, over and over. Let's close up a little and not ask the same question, over and over.
john curl said:
[snip]I don't understand why I have to answer the same questions and challenges, over and over. Let's close up a little and not ask the same question, over and over.
Well, sure, but it was you who brought it up John:
Jan Didden
WHAT IS IMPORTANT. Matti Otala continued to maintain that 'slew rate' was not the only factor in why amps sound different. He maintained that the high open loop bandwidth was still important, EVEN THOUGH WE COULD NOT UNDERSTAND WHY, AT FIRST!
This is his legacy, I would have given up. PIM is the key, at least the first key to open the next lock in optimum audio reproduction. This I believe, and sooner or later it will become obvious to each and every one of you. This I predict from listening, not measurement.
Perhaps because Otala and yourself were flat wrong then and today as well? I think Bob and others proved this beyond any doubt.
If there is any kind of (or way to) proof that you would accept in this particular matter, name it, I'll try to provide it. So far, you got everything from phenomenologic descriptions (Bob, Jan) to advanced math (Andy) to measurements (Bob), to simulations (Bob, jcx and others).
dimitri said:
Ovidiu,
Jan wrote: Well, if you look around you with your eyes open for more than a few seconds it becomes abundantly clear that reality and nature is a lot of things, but not black and white.
Dimitri,
Have you mentioned the same quote to your friend?
Otherwise, speaking about black and white, I would appreciate a qualified opinion from your team about where and how were Otala and John Curl incorrect in this matter.
Nobody is denying Otala's contribution to the PIM theory and practice. What is under fire is the NFB correlation with PIM (and many other three letters acronyms).
dimitri said:
I don't understand what are you asking for; I can probably discuss where and how did Otala and John Curl overestimate smth...
I think you understand perfectly. But you must have very strong reasons to defend the undefendable.
Otherwise I agree that this discussion goes nowhere, therefore I'm over and out, unless:
Jan,
I agree that Otala revealed this mechanism, but it is not correct that it can only be avoided with his type of amp (low OL gain, low FB factor), as has been shown for instance by Cordell, together with clear measurements
I'm sorry to inform you that low open-loop gain and wide bandwidth are unconditionally essential to lower dynamic (and other) distortions. Inaccuracy in time and transients cause GNF to passingly (but frequently) lose control over the close-loop gain and the output signal.
I doubt such a rapid course of events can be measured reliably
Should we compare what we dislike to decide what is the best amp topology?
Maybe we should do that on a beautiful day.
Electrocompagniet stated (in my quote) that increasing the FB by 10dB significantly improved the sound. And since this amp enjoyed a lot of success, you can't just blame a confused engineer here.
Look, I`m not asking you (or anyone else) to agree with me, just to understand what I`m trying to say. I stated quite recently that the need for GNF depends on the open-loop characteristic, which is decisive for the perceived sound. If the sound does not live up to expectations, a suitable amount of GNF will make it less unbearable, otherwise it would be unfortunate to apply GNF.
Come on John, are you saying that listening to amps tells you PIM is an issue??
I really don't understand your stance on this. Several people have made a quite good case with math, reasoning, measurements, that PIM is no longer an issue. You yourself have never even measured it. You have not been able to even make a small dent in the offered evidence. There's nothing to support your position other than what Matti said 40 years ago and that since has been shown to be not quite as he said.
Is it so difficult to embrace new information and learn something new once in a while?
Earlier you complained that you have to 'explain this 100 times'. Well, if you bring this up again and again, people will refute it again and again. If you want to break that cycle, either come with new evidence or don't bring it up.
It's really easy.
Jan Didden
Lumba Ogir said:
Jan,
I'm sorry to inform you that low open-loop gain and wide bandwidth are unconditionally essential to lower dynamic (and other) distortions. Inaccuracy in time and transients cause GNF to passingly (but frequently) lose control over the close-loop gain and the output signal.[snip]
I'm sorry to inform you that this is not true for a competently designed amp. And of course, these are the only ones we consider!
Lumba Ogir said:
[snip]Maybe we should do that on a beautiful day.
[snip]
Sounds like a good idea!😉
Jan Didden
