Matrix of identical loudspeakers implications
Hello, can you please comment the following full-range configuration which I'm testing. It works good on the paper and in ambient, but I have some concerns about anything could be inappropriate in the design (distortion? intermodulation?). We have in fact:
Two identical drivers in parallel, but one in a closed box, and the other in a separate bass reflex box
AND
Two identical drivers in series, in the same closed box, but each wired with a different electrical cell
Do you identify anything odd (see attached)?
because you will get unpredictable results, with the high-passed FR acting as a filtered passive radiator. but you can always try it, of course!
i do not understand why you would like to use two (identical?) fullrange drivers and drive one through a high pass and one through a low pass. you essentially have a similar output as with just unsing one unfiltered FR driver, but with added cost, interferences ....
also keep in mind that serial crossovers are less predictable than parallel ones.
edit: did you try to simulate this complex crossover network?
