Does any one here know about routing audio in Matlab? I'm running a program that does HRTFs and I can't get audio out any soundcard. The program opens and functions fine, but when loading tells me that it does not know how to output audio on my computer.
It's old software from UC Davis that was last updated in 2012, before Windows 10, which is what I'm using using. Originally it ran on Matlab 5. I am running Matlab R2020b on Windows 10
Two scripts seem to be blocking me, and as I've never before used Matlab, I don't know how to edit the files for my system. check_sound.m runs first and tells me "I'm sorry, I do not know who to output sounds on your operating system"
It seems that check_sound.m calls play_sound_array.m to do the routing but I have no idea what to change there.
Can anyone help with editing this so that it outputs sound on Windows 10? Default soundcard is fine. If I can choose the USB card, even better.
Code:
% Script to check the OS to see if sound output is possible
% Copyright (C) 2001 The Regents of the University of California
play_sound_flag = 1;
switch computer,
case 'PCWIN' % MS Windows
if (exist('wavplay') ~= 2) & (exist('sound') ~= 2),
play_sound_flag = 0;
if show_warning,
fprintf('\n I''m sorry, but I could not find either wavplay.m\n');
fprintf(' or sound.m on your MATLAB system.\n');
fprintf(' You can still use the graphics features,\n');
fprintf(' but the ''play'' actions will be unavailable.\n\n');
fprintf('Press any key to continue ... ');
pause;
fprintf('\n');
end;
end;
case 'LNX86' % Linux Intel for Matlab 5
if exist('sound') ~= 2,
if show_warning,
fprintf('\n I''m sorry, but I could not find sound.m\n');
fprintf(' on your MATLAB system.\n');
pause;
fprintf('\n');
end;
end;
case 'GLNX86' % Linux Intel for Matlab 6 R12
if show_warning,
pause;
fprintf('\n');
end;
end;
otherwise
if show_warning,
fprintf('\n I''m sorry, I do not know how to output sounds\n');
fprintf([' on your operating system -- ' computer '.\n']);
fprintf(' If you know what MATLAB function to call\n');
fprintf(' to output stereo sound, do the following:\n');
fprintf(' 1. Edit the case statement in ''check_sound.m''\n');
fprintf([' to add the additional case ''' computer '''.\n']);
fprintf(' 2. Edit the function ''play_sound_array'' to include\n');
fprintf(' an appropriate call to your sound output function.\n\n');
pause
fprintf('\n');
end;
end;
Code:
function play_sound_array(sound_array, fs)
% function play_sound_array(sound_array [fs])
% Plays the sound data at a sampling frequency fs,
% which defaults to fs = 44100.
% Assumes that sound_array(:,1) is the left channel
% and that sound_array(:,2) is the right channel,
% and that the maximum absolute value of the values
% in sound_array is less than 1.
%% Check for valid arguments
if nargin < 1,
fprintf('Format: play_sound_array(sound_array [fs])\n');
return;
end;
if nargin < 2,
fs = 44100;
end;
num_channels = size(sound_array,2);
if num_channels > 2,
error('sound_array cannot have more than two channels.');
elseif num_channels == 1,
sound_array = [sound_array sound_array];
end;
%% Use proper sound output function
switch computer,
case 'PCWIN' % MS-windows OS
vernum = version_number;
if vernum < 6,
sound_array = sound_array(:,[2,1]); % Swap left and right channels for 5.x
end;
if exist('wavplay') == 2,
wavplay(sound_array,fs,'sync');
elseif exist('sound') == 2,
sound(sound_array,fs);
else
fprintf('\n This message should not appear.\n');
fprintf(' Unable to find either wavplay.m or sound.m\n\n');
end;
case 'LNX86' % Linux Intel OS for MATLAB 5.x
else
fprintf(' Unable to find sound.m\n\n');
end;
case 'GLNX86' % Linux Intel OS for MATLAB 6 R12
else
end;
%%% Insert other cases here %%%
otherwise % Unknown OS
fprintf(' If playing sound has been enabled,\n');
fprintf(' you need to edit play_sound_array\n');
fprintf(' to specify how sound_array is\n');
fprintf(' to be played.\n');
end;
Ah ah! The function wavplay is now obsolete. audioplayer is the current function. I'll try using that instead.
I made some progress by creating a new case called PCWIN64 and by calling audioplayer instead of wavplay. But still get errors farther down the line. 🙁
I used this little script to direct calls to wavplay to audioplayer instead
and made a little more progress, but am stalled at:
Error using wavplay
Too many input arguments.
Ah well. That' what happens when you are a MATLAB newb. I'll keep at it and might learn something. 🙂
Code:
function wavplay(signal, sampleRate)
% WAVPLAY Plays an audio signal using the audioplayer object.
% WAVPLAY(x, Fs) plays the audio signal x at the specified sample rate Fs.
% Instantiate object to play audio data.
player = audioplayer(signal, sampleRate);
% Play signal from beginning to end (no overlap with other code possible).
playblocking(player);
end
Error using wavplay
Hello Pano,
Your function wavplay works fine in my Matlab 2017a and Win7 Pro.
The argument "signal" must be a two-column real array, and "sampleRate" a real scalar, i.e. a 1x1 array.
Regards,
Braca
Regards,
Braca
