Matching transistors - Measuring hfe
Hi mchambin,
Still, any unbalance condition will increase distortion. Once you're past a certain point the distortion rises rapidly with lack of balance increases.
The best performance occurs when the rest of the design is balanced and tends to run the DC offset to zero. Then highly matched diff pairs can really make a difference. The diff pair will naturally try to correct for any non-linearity including a DC offset. Small DC offsets do not adversely affect the operation of an amplifier, so if there is a trade-off to be made, design so that the diff pair remains balanced in normal operation.
-Chris
Hfe. Vbe will not be very different between Hfe matched transistors and you may well be able to achieve both. My own experiments have shown that a matched Hfe to give the lowest distortion, and technical books on transistors support that for the most part.
Matched Vbe only matters in temperature sensors where you are measuring differences in Vbe between two or more points. Other than cases like that, I can't even understand why this is a question.
-Chris
