Matching Mosfet already in Amp
That would give you a pretty good idea how close they are matched, but you would be assuming they are all conducting the same current. That also depends on how close the source resistors are matched. Not the best way, but you can tell if there is a gross mismatch causing one to conduct perhaps 5-10% more than the others.
