Matching jfet at what voltage?
Yes, I would use 20 Volt.
Matching at 10 Volt would most probable be good enough,
but I like to match at the level devices should work.
When matching high power transistors, it is not as easy
to setup a situation with lots of power and heat.
But for small signal JFET and BJT this is less of a problem.
