Matching Beyer M55 and Philips EL6431
Moderator
Joined 2003
I've got this classic Beyer M55 microphone and would like to wire it correctly to the mic input of the Philips EL6431.
Microphone comes with three wires and a shielding, amplifier mic input has the three plugs, hot, cold and ground.
Full schematic of EL6431 here.
I have no data on the M55 except this picture:
http://users.pandora.be/oldmicrophones/all_thumb_beyer_m55.html
/Hugo
changing beyer m55 din plug for xlr
Hello,
iv'e just picked up an old m55 and want to rewire it with a male xlr connector to replace the 3 pin din.
It is identical as the picture above with a three core cable plus a shield. How should I wire this to the xlr ? Other mics I have wired have used to a two core plus shield. Do I need to bridge the pins, or wire the shield somewhere else?
Any help would be greatly appreciated as would any opinions on the m55 and its uses.
Many thanks.
Had a mess about with the wires and all is working now and sounding nice!
Realised that connecting either the blue or white wire to xlr pin 2 decides the hi or low impedance, the other is not used. White lo, blue hi.
cheers
I had a quick listen to the M55 last time and believe it must have been a reporters microphone. Small, robust, handy and a perfect 'Hi-Fi' quality for AM broadcasts. 🙂
I could be wrong of course.
-=Hugo=-
