MASSUSE ME-2-9B Relay
Thank you. Yes i wa looking at some Omron high sensitivity models.
They match in everything except few things...
Massuse contact data
Rated load: 1A/125VAC, 2A/30VDC
Max. switching capacity: 60W or 125VA
Omron contact data
Rated load: 0.5A/125VAC, 1A/25VDC
Max. switching power: 65.5VA, 24W
And operation time is not the same:
Omron has:
7ms, 4ms
Massuse:
6ms, 3ms
Power consumption is same. So i am not sure about switching power and rated load.
Its Omron G5V-2-H1 9DC model.
Not good i think?
Edit:
And Nom Coil Voltage DC:9V for Omron and Nominal current for Massuse is 16.7...
Please use OMRON G5V-1 9V.
The relay act only as mute. You can short across the relay. Just make sure you power on the amplifier after powering up DACMAGIC, and to power off the amp before powering down the DACMAGIC.
How did you break it anyway?
