Marshall EL34-100/100
yeah it's an all tube rack-mount power amp. It's on their site under products/rack products.
They also have an EL34-50/50 and EL84-20/20, 20, 50 and 100 being the wattages. it's there twice because they are dual monoblock meant to be used as a stereo solution.
This is a power amp for guitars. There's a switch on each channel for two different modes which could be equated to a bit of a preamp, but other than that there's not much.
The thought here is that you're going to use an effects processor to do most of that, and this just provides the raw power.
I believe the Deftones guitarist uses them. With 2 midi preamps in front of them. And LOADS of processing 😱
