Greetings,
I have recently repaired a friends amp due to blown TDA 7293 Power Amp failure. Thanks to all who have posted info in regards to this. The posts in this forum allowed me to troubleshoot and fix the problem on two different occasions now.
To summarize the problem, the fuse was blown and both TDA 7293 chips were blown. Therefore no worky. The first time I fixed this amp it was the same problem, bought some new chips and re-fit them, all was well. It worked for about a year under heavy use and then the same thing happened. This time, bought new chips, changed them out, turned it on and then immediately blew the new chips.
After evaluating the Vs levels on the chip, solder connections on the power amp module, and other points of continuity, this is what I found.
The Vs levels were +- 49V so this was good and no other burnt components in the amp, so after closer inspection I found pin 12 on the TDA7293 (Bootstrap Loader) was not making connection with pin 8 on the power amp board connector, the pad was mangled from soldering/desoldering. I installed a jumper wire on the back to fix the problem and to eliminate future problems, I removed the socket pins from a typical IC socket I had, and soldered these into the holes of the power amp PCB. Now when these chips go bad again, I can simply plug a new one in rather than risking more damage to the PCB
After checking all connections and voltage levels again and then again, I installed two new TDA7293 chips into the sockets, reluctantly turned it on, and thankfully all was well again.
Does anyone have any input as to why the bootstrap loader pin being disconnected would cause a short that would smoke the chips upon power up? Thanks.
Marshall valvestae 150 burnout
I have 2 of these amps in a rehearsal room i operate. Both have run really well but just today had a burnout.
The amp smoked and cut off witrh the ever distinct smell.
What is this likely to be? I am new to amp repair but comitted to learning, so i can sort these thing out with out costly repair centers.p
It's probably the tda 7293 chip like the story above.Replace it and it will work like new but check all pin connections before and after soldering like
the pin8 is making contact with the relevant component elsewhere.Also if other component is shorted or pcb track broken before switching on again,it pays to check.Ps make sure you apply silicone /heatsink grease to the back of the 7293 chip for proper heat conduction, it comes in a tube like toothpaste.And don't overtighten the screw.Just tight enough will do.
Regards.
Regards.
Honestly, I think that the problem here is the TDA chips are simply being worked too hard with inadequate cooling. Guitar amps have to be very RUGGED as playing pushes them into clipping and distortion which greatly increases stress. I am not a guitar player myself but i would be weary of any solid state guitar amp (except perhaps small practice amps) that do not have oversized discrete output stages.
I would agree with jaycee.. there's more fault's with these unit's I repaired 15 or so and all with the same fault crappy o/p stage's broken front pot's and damage preamplifier stages etc...yawn...
to ensure the front end is ok remove the blown o/p stage and power up, next feed a signal in and use the line out on the rear and link this to a scope if handy or a small test amp. now turn up the marshall's pre-gain just a little followed by the master that done turn up your test amps volume to hear if you have clean level. if you have clean sound and tested all the channels for the same level's the front end is ok.
Now, the ht is high for the tda7293 and is close to it's limit no wonder it goes pop..bang and smoke.. oh did we forget them fans as they start groaning on start up! plus them under rated power cap's 'only a 1000uf '...up grade them to 3300uf or 4700uf 63vdc much better now on to the power stage...you could get replacement o/p power ic and board and end up with the same fault time and time again...here's a good fix that will last better than the 'old chip' stage..just fit a power stage that will work on the supply rails say +/-dc of 55v..60v and tap the signal from the main pre-amp and there you have it..
I've done is to all the one's I've repaired and there still in working order..
there's plenty of kit's out there that will do the job..I built a power stage fitted them to the amps. line 6 amps use these ic's at less supply rails and last better!
I agree with Jaycee....the problem here is the TDA chips are simply being worked too hard with inadequate cooling...I would be wary of any solid state guitar amp... (except perhaps small practice amps) that does not have oversized discrete output stages.
The trouble is that powerful amplifier chips generate heat, and because audio power chips are small, all that heat has to be removed through a very small contact area.
This simply doesn't work very well in a guitar amp which is being worked hard, so the chips overheat repeatedly, and the stress kills them eventually. It's like putting an undersized radiator in your car - eventually, that will overheat and kill the engine prematurely.
New-fangled class-D chip amps help quite a bit, because, for the same amount of output power, there is much less heat to get rid of.
Otherwise, if class AB is in use, the only reliable solution is to increase the area through which the heat can be removed from the chip. In other words, use big discrete power devices, as Jaycee said.
-Gnobuddy
There are 2 versions.I have this amp and no output. Does anyone have a schematic on this amp?
Does yours have TDAxxxx chipamps or large power transistors?
If unsure post a picture of the power amp / heatsink area.
See if these look right..........
- Live Sound
- Instruments and Amps
- Marshall AVT150H Valvestate 2000 Power Amp Problem
