Hi i have a problem with my ps1 lcd, i have some marks on it and it is showing up on the wall. the marks are on the film, do you know if i can get some new film to put on it.
thank if you can help?????????
You can take the front anti-glare and the rear Tac off the Psone fairly easily.
"Rag Soak" the front for about 4 hours and the back for about 3 hours. Use a razor and pull up the antiglare and do the same for the rear Tac. They both are thinner than a piece of paper. So make sure you are pulling them up and not the polarizer also.
