I plan to change from FOSTEX FF85WK+BH to MarkAudio CHN50P+TQWT for TV.
If I use it for a while and don't like it, there will be no change.
There's a resonance that causes a dip at around 1.5-1.8KHz?
The graph is without smoothing, so peaks and dips are clearly visible.
I don't know the cause of the 1.5-1.8 kHz dip, but I don't feel any discrepancy in music playback.
The impedance graph also has a peak around 1.7kHz.
CHN-50P mica has power and beauty, and is my favorite 3” from Mark Audio.
CHN50P mica > MAOP5 > CHN509 > Alpair5v3 > CHN50
[Air-Recording] This Masquerade / Carpenters
[Air-Recording] Take Five / Helge Lien Trio
[Air-Recording] Respighi - The Pines of The Appian
I installed Alpair 5.2 on DDVP-08-ML and it sounds good.
TQWT is very versatile and can be enjoyed with various drivers.
Hi xXBrunoXx,
I have not listened the PS95, but Dayton Audio also has many good drivers.
There are design and cut drawings in the top post, is there not enough information?
I just finish my build with CHN 50P mica in your HBW-08 box
How to say.... what to say....
they are wonderful
the high are perfect, and beautiful
the voice are superb
guitar and piano really realist
the acoustic scene is less big than the maop 10 and the sb 20 that i have but still there
for sure all the frequencies are not there but in precision it beauty he can be compared to maop 10.
due to the small price of the speaker i should know what it could give to 6-10 speaker like this in my room
don't hesitate the speaker is really a good investment, it's an high value for the price
they are wonderful
Pierrick59, thanks for the follow-up test.
HBW-08 is not expected to have much bass, but it works well with the CHN 50P mica and gives a nice vocal sound.
I am looking forward to hearing how it will sound with multiple units.
The voice coil has a large diameter and the damper area is small, so the bass is not so high.
The sound quality is refreshing with little distortion.
- nandappe
- Forum: Full Range
I find this very interesting. What advantages would you say it has over the Maop 5?CHN-50P mica has power and beauty, and is my favorite 3” from Mark Audio.
MAOP5 is slightly better in texture and subtlety, while CHN50P mica is subtle yet powerful.
I prefer MAOP5 for mid to high range and CHN50P mica for all range.
Perfect insight. Thank you.I prefer MAOP5 for mid to high range and CHN50P mica for all range.
I was considering either option for a WAW so mid/high is the critical component.
Did you use any sort of filtre or EQ to get that FResponse ?I plan to change from FOSTEX FF85WK+BH to MarkAudio CHN50P+TQWT for TV.
- Full Range
- MarkAudio CHN-50P mica + TQWT(DDVP-08-ML) for TV
