The high Q of this driver makes it go very low in a bigger box, and the bass is very articulated . My speaker has 31 liter box volume and a Monacor BR60 tube . This gives a tuning frequency of the speaker at 35 Hz .
At this frequency, the chn110 is standing still while all sound comes from the port, allowing rather high spl down to about 30 Hz .
I combine this with a dsp high pass crossover set at 33 Hz 24db/oct with the help of a WiiM ultra .
This speaker can play louder in the deep bass than my former SAM 8340 speaker.
I see a lot of constructions with horn loading and that’s fine, but you have an advantage with the backpressure from the tube in a ported speaker, lowering distortion significantly in the bass area.
With a high Q driver like chn110 one can tune the speaker below the fs frequency of the driver , this is not the case with a low Q driver.
Scottmoose can probably write more info on this .
Right, the break point is ~0.403 Qts'.........
FYI/FWIW, IME and proved to my satisfaction when 'proofing' MJK's MathCad design programs against some of my own Tower/Column alignments from 'way back when', the vented TL (closed pipe) alignment (aka MLTL) range from ~0.312 - 0.624 Qts' seems technically good enough, i.e. from Keele's 6th order assisted bass reflex to his Extended Bass Shelf (EBS) alignment.
While the 'sweet spot' (mean) is a ~0.4412 Qts', a 'close enough' simple guideline is:
~0.403, Vb = Vas, Fb = Fs
~ <0.403, Vb = < Vas, Fb = > Fs
~ >0.403, Vb = > Vas, Fb = < Fs
Keeping in mind that one has to factor in the (huge) impact thermal power, inductive distortion can have on effective Qts, the dominant vented box alignment factor.
(Qts'): (Qts) + any added series resistance (Rs)
Not much I can add [no surprise there 😉 ] to what GM has said there. The only two notes I'd make are
a/ A [well-designed] bass horn is always the most efficient back-load for a given tuning, or I suppose more accurately, it offers the potential for that. It's related to a vented box, they just happen to be moving in opposite directions on a sliding scale
b/ Vented loading, like anything [whatever variation] only goes so far. Using the example here, CHN-110 was designed to want by current standards a relatively large enclosure for its size & offer the potential for decent LF extension. And you can certainly get that, as GM shows above, & the various boxes I've done for it are meant to demonstrate. The price for that can be power handling, unless you start introducing some slightly broader-band loading -which takes us back to pipes, horns &c.
