Hello,
I have a Mark Levinson 436 that has 21 volts on the output.
Initially the amp had a slight pop when powering on, so I attempted to adjust the servo voltage with R1. When attempting to adjust it to below 100mv the reading was around 3.5 volts. Adjusting R1 would not reduce the voltage, but the voltage actually went up to about 4.5 volts, and would not go down from there. I replaced R1 which allowed this to go down to 112mv. It would not go below that, and now there is 21 volts DC present on the output/speaker binding posts. I have replaced all electrolytic caps on the VG board, but there is still 21 volts DC on the output.
Any help in finding the issue would be very much appreciated.
Thank you.
Thank you.
The amp is now going into protection after switching to On. Protection mode does not activate in Sleep or Standby. I am guessing that it is detecting the DC at the output when switching to On and is activating protection mode.
Any suggestions as to what is causing the DC to be present on the output?
Thank you.
Thank you.
I removed the VG board from the amp and installed it in another 436 that works fine, and it triggered protection mode as well as causing the same amount of DC voltage to go to the output.
So I now know that the issue is on the VG board.
Hello,
I also have a Mark Levindon 436 with a defective VG board. But nobody is willing to repair the board and spare parts are not available.
Have you found a solution for a defective VG board?
Thanks in advance, Mike
Currently the Mark Levinson are at Escoor the Mark Levinson repair shop in Germany. I have asked them to provide the voltages.
Let the people at Escoor do what they have in mind.
It's no good to let two parties concentrate on the same job.
Hans
Hans
Sorry, but that’s absolute nonsense.
With the exeption of the micro processor that never breaks down, all part are readily available or have perfect replacements.
I know from experience what I’m talking about.
It seems almost as if they can only swop complete boards, and yes these boards will be hard to find.
Hans
Hans
Surely someone in the USA can repair the boards. But they may want the entire amplifier in their possession to do it.
Hello everyone,
I have now picked up the power amplifier from Escoor and found someone in southern Germany who has already repaired several Mark Levinson power amplifiers.
So I'm driving 600 KM to the south at the weekend.
I still have a few questions:
Thanks for any advice, Michael
- Are there any tips/instructions I could pass on?
- Can I avoid the same thing happening to the second amplifier?
- Can the power amplifiers be placed on top of each other?
I have only one advise, let them make an offer in advance with a guaranteed maximum price plus a no cure no pay option.
And don’t accept to let them expensively recap the whole amplifier as a precaution which is in most cases a waste of money.
You can’t prevent the other amp from happening the same.
The 400 series is notorious for mishaps caused by a few transistors working outside their comfort zone.
Hans
Hans
I have the same issue with one of my 436’s. Were you able to find a solution? My dealer told me there are no spare parts and I now have a very expensive paper weight.
It could be that a new VG board will be designed, not having all the anomalies that most 436 Amps have.
In one or two month’s more will known.
Hans
Hans
- Mark Levinson No. 436 With DC On Output
