Mark Levinson ML3 or No23 ????
Does anyone know what the current market value is on this amp?
Would one prefer the No23 or the ML-3? I know the ML3 has variable damping but I think this is just a gimmick in which Carver did the same thing.
Yes, this would be interesting to know. No experts here concerning this models? P.S. from No23 I have schematics getting about reverse engineering (drawing according the the PCB's) - except the main voltage select unit.
Hi John,
I've had several ML-3's I really liked.
ML-3's nowadays almost demand the double amount of cash compared to their succesor the No.23. All the ML-gear as very expensive at the moment like the old Thresholds.
The variable damping is as far as I know a kind of NFB switch. The higher the dampingsetting the more Negative Feedback.
If you do not need the power go for a set of ML-2's. I found these really magical sounding on my electrostatics but they only put out 17 Volts max.
