Many. What is your application?
dave
Listening music 🙂..
1/4 wl would be a different design than usual bass reflex ..and i'm in the impression that bass is better controlled?
Depends on how well designed and executed. It does allow one to use a larger volume to get lower bass without an ugly alignment.
I like them.
dave
I like them.
dave
Ok i understand, need then to select the well made design .. any suggestions ?
I read a lot about pencils, but thede are BR .. didnt find yet 1/4 designs other than the needle series from omnes audio wich mostly use tang band drivers such as the W4-1879
Thepinguin,
AFAIK the Pensil designs done by Scottmoose are MLTL variants and hence quarter wave designs.
Scott, Dave,
Please correct me if I am mistaken.
Scott, Dave,
Pensil is an ML-TL. Lots of them for Mark Audio drivers. The Pensil alignment is such that it has goos midbass punch and reasonable extention, some of the taller ones go lower.
http://wodendesign.com/downloads/Quadrapole-P11-MLTL.pdf
dave
dave
I've just done a brief stock-take (as it were) of quarter-wave enclosures I've done for the MA units. Aside from the pensils, a very incomplete list includes Pudu, Okapi, Gerenuk, Eland, Water Buffalo, Kewel, Sitatunga, Oryx, Hirola, Pangolin, Sea Stack, a couple of unnamed compact QWs for the CHN50, Bastle, The Thin End of the Wedge, and few other unnamed ML-Voigts and twin-pipe Nessie type enclosures for a variety of units in the range. That's not including horns like the FH series etc., and just boxes I've done -there are plenty of others, so there should be a reasonable choice of quarter-wave enclosures out there.
Lots of drawing to do!
Girraffe for A5..2/5.3, CHN50 is missing from the list and i am sure i could find others.
A lot of MA ML-TLs just from Scott.
dave
dave
- Full Range
- Mark audio's line of products
