Does anyone own a Marchand "Bassis"? What are your thoughts on this unit? Are there other good devices such as this that work well with tuning Subs? I'm in the process of tackling my first sub project, so I'm doing my materials research. I have built several 2 way designs with great success and now I need to fill in the low end of these speakers. I'm also having a hard time deciding witch driver to use. There seem to be lots of great options but unlike reviews on equipment and the ability to run down to your local stereo store and listen to speakers, there is now way to tell if the driver you are about to buy is the sound you want. Luck of the draw I guess. Any way I have narrowed it down to the TC15 by TC Sounds, Bluepoint 1503, or one of the Lambda drivers. Would anyone say I would be wasting the intended design of a TD driver by Lambda, since it seems these were intended as a mid/low bass driver for horn systems, but I would only want to use the low end. What I'm looking to build is a music only sub, I have another sub already dedicated to my home theater. While I find this sub great for home theater, I don't quite like it for music application, it's a bit slow & muddy. So I'd like to build a sub with more attention to detail, accuracy with fast/punchy bass. So how has played around with these drivers and what are your thoughts? Are there any web sites set up with projects using any of these drivers?
Thanx
Dru
Thanx
Dru
