I am replacing the laser pickup on my Marantz UD7007 and I can't find any jumper or solder bridge on my replacement that protects the pickup.
Does anyone know where the jumper is located? I've attached a photo. The other side also does not have a jumper.
Thank you,
Thank you,
Hi Bargainhunter, I do not have the answer on your question but I have a question to you. I read in an other forum your post about the Marantz UD7007. It failed to start working. Could you inform me about this issue. Have you found a solution to make it work again. I have 2 players with this same failure and can not find the problem.
Hope to hearing from you.
Regards,
Rien
Regards,
Rien
