Marantz PM94 service manual
Perhaps I'm overlooking something, but the first step of the idling adjustment procedure appears to be incomplete. Step 3 namely mentions R642 and R742. Do I need to put these 10K resistors in circuit in step 1?
  • Adjustment Procedure PM94.pdf
Not sure.what the huge error would be. My experience is that you ways need to check the values of listed parts like capacitors to the values in the schematics.
My issue is that the adjustment procedure isn't clear to me. Perhaps someone can shed a light on this?
Also, I have done a full recap apart from the filter caps. Should I check/ readjust the bias? Reason I"m asking is that the left side feels warmer than the right side of the amp. If so, should I first replace or clean the pots?
