Hello,
I'm looking for assistance with a Marantz DV7010 which I want to use to play CD's out in the garage etc.
Notable observations:
1. plugged in, power off: standby LED is NOT on, it should be.
2. service test: Standby LED does light.
3. power on: no faults listed on display; display checks OK in service test.
4. push open button: drawer extends then immediately retracts
The standby LED is controlled by the main microprocessor so the fact that it is off means something, exactly what I can't find out.
According to searches #4 is symptomatic of a dead/dying laser reader.
Apparently the DVD mechanism is a Pioneer unit and replacement parts are readily available.
I just want to check with all y'all and see if replacing the laser is the best first repair.
Thanks for reading this and I definitely appreciate all comments.
Did you check the belt? Might be that the drawer does not fully extend due to a slipping belt and thus immediately retract back. Just a thought, I don't know that exact model.
Check that the Switch sensing when the Tray is open is being actuated and it's contacts are clean.
On Pioneer's this was always a favourite.
Also, is it perhaps in some 'Audio' only mode which may kill all the display for quiet 'Audiophile' operation?
Check the Manual for such a function.
Just some thoughts.
p
Just some thoughts.
p
I was too optimistic about the belt, the group I ordered a belt from cancelled my order, no stock
I measured the belt with a hole saw:
52.25mm ID
it feels just as elastic as you would expect a 20 year old rubber band to feel.
I reckon I'll search the auction sites for a 2" belt
I pulled out the switch:
Percival, what's the best way to clean this?
thanks
Mac
52.25mm ID
thanks
Mac
hello!
I changed the belt
I cleaned the switch doused it with contact cleaner and waggled it a dozen times
put it back together
Voilà! the door opened and stayed open.
it plays DVD's!
it won't play CD's unfortunately.
any suggestions?
oh the standby lamp is controlled by the main ECU. it's still not on when power is off. must mean something.
thanks
Mac
I changed the belt
it plays DVD's!
any suggestions?
thanks
Mac
it plays DVD's!
any suggestions?
Might be a dead or weak CD Laser. The pickup usually contains two Diodes, one for CD and one for DVD. You might be able to get it back to life by increasing its power output, but more probably you'll have to replace the whole pickup.
- Digital Source
- Marantz DV7010 need help with drawer immediately closing after opening
