martin clark said:Offer to etch the turkey too, & see how far that gets you
Oof, a dirty look BARE MINIMUM!
6h5c said:No, you need a scope for that. You can monitor the HF signal at R105 (TP13) and adjust the current with the small trimpot that's on the flexfoil of the laserunit. If you remove the three screws that hold the transport and tilt it >90 degrees, you can easily reach the trimpot after you take out the drawer, without having to disconnect anything. Then pop the drawer back in and measure again to see the result of the adjustment.
Ray
I find the same problems with the VAM laser on the 63,67 & 6000.
Yes the 6000 is easily sorted with the cap but to get the laser perfect in the 63 and 67 you need to adjust grating. The grating is not supposed to be adjusted but i find it cures it. The grating is adjusted by the two grub screws on the laser
If you are doing it blind (no scope) adjust one screw 1/4 turn in one direction and test the tracking, if it gets worse turn back and if it gets better turn further to test etc. One screw will not make much difference (can't remember which one).
Brent
Ah, thanks Brent, just like the good old Pioneer units 😀.
Maybe i'm going to give it a try. Is there also a way of measuring it? I remember with the Pioneers you had to look at the EF balance signal or something like that, and watch for a small pulse to appear on the scope.
Ray
Ray
My Xmas gift:
http://dl-3.free.fr/52616e646f6d495...ec0f3b65fc41bc6d2f137a838bb/NouvelleVague.zip
Please not this is Apple Lossless codec.
Edit : this have been deleted from the server... they caught me!!
I'll find a way...
I'll find a way...
SimontY said:hahaha, Christmas eating, yum!
Nice job there Ray, it looks as neat as we expect from you. Is it similar to Disco's pcb?
Simon
Thanks Simon. Yes, it's similar, the circuit is about the same. I included the voltage regs on the PCB and altered the current sink a bit.
Ray
6h5c said:Ah, thanks Brent, just like the good old Pioneer units 😀.
Ray
Off the top of my head im not sure of the point to test. To be honest I usually just do it without a scope
Brent
happy christmas all, thanks for all the info over all the posts, its been so helfull. Have a happy new year and hope all your mods come true 🙂
http://dl-1.free.fr/52616e646f6d495...7efc788537285a4ff01a94ea9ae2/CD53TOCD63.KKDZO
Here is my gift again, please take it now!!
Rename archive as .tgz and it will work. Inside is Apple Lossless codec disc.
Hi Guys,
For all of you out there a Merry Cristmas and a Happy New Year and may we discover new modifcations for our audio equipment!
Thank you all for your commitment and for a lot off good ideas and tips we shared on this tread.
Greetings,
Peter
Greetings,
Peter
Hi there!
Here I'm back with headphone tune. I know It may be nice to have a dedicated HP Amp...
Is there any OpAmp "more suitable" for the HP part than the LM4562? Maybe one with less output power? I just want to lower even more the output. (gain from 2.25 OEM to 1.1 now, still too much! ).
Hi everyone,
Done a few searches and cannot find anything... Is it worth spending a bit extra on the Superclock 3 Ultra-low Jitter Audio Clock - 16.9344MHz over the Superclock 2? This is for a CD-63 coupled to an Audiolab 8000s.
just my opinion, dont think you would hear any difference without an awfull lot of other mods. just my opinion though. id say put your cash into some decent interconnects or superegs for the analogue and digital supplies.
dennis
dennis
ooops that should read get the superclock 2 and the rest of the cash for say its own psu and also some other mod components !!!
Ray,
Can i check with you if your mod list the 100n X7R is the one here taken from farnell singapore.
Epcos 100n X7R
Can you also help me in locating the 100n PPS, i am sorry i am quite a nerd with these small electronic parts..
regards,
marcus
Epcos 100n X7R
regards,
marcus
marcusdeming said:Ray,
Epcos 100n X7R
regards,
marcus
Hi Marcus,
All the 100n X7R I used are through hole, the one you selected is an SMD cap. Allthough that doesn't mean it can't be used, soldering it on the PCB can be a bit tricky
Ray
6h5c said:
Thanks Ray, so i am supposed to solder them below the caps, underneath the pcb, for those where the remarks column state a "+100n x7r" or "+100n pps". If i am not mistaken, this is more impt for the circuit at the DAC and opamps right?
btw whats the meaning of "PPS"...?
regards,
Marcus
- Digital Source
- Marantz CD63 & CD67 mods list
