Marantz CD-60 NON-OS Tuning
Hi Folks,
i would like to tun-up my Marantz CD-60 and i need some
assistence to build it to a NON-OS by using the TDA1541A !
I read a lot about the 1541A here in the DIY-Audio
Forum but i can´t apply direct to the PCB !
I got the Service Manual and I want to change a lot of Part´s
like exchanging all Resistor where Sound passes to NON-Magnetic by Vishay-Dale or all standart CAP´s relaced to bigger ones by Nichicon MUSE and Panasonic FC Gold Series !
Normal Foil CAP´s out and MKT in.
DIODES like 1N4002 kicked by Schottky or IXYS-Diodes !
But the MAIN-THING is to make a NON-OS Player !
Does anyone got experience with the CD-60 and can help me ?
Also witch one is better Nichicon MUSE, Rubicon or
Panasonic FC ?
Vishay-Dale or TKD Resistor ?
best regards Carracho
thx Random
I Know tnt-audio !
On this site Peter Campell tunes a CD-60 Output OPA and on the next steps he gives a cleaner Voltage to the TDA1541A
nothing else :-( !
I intent to listen this OP´s
AD275GP
OPA627
AD825
OPA2134PA
OPA2604AP then i will hear witch on touch my taste !
I have contacted ecdesign.nl ! watch here in diyaudio they
have a lot TDA1541A project ! So mayby these guys can
give some hints t apply NON-OS direcly on the PCB !
Sorry for that long Delay :-( a little bit bussy . . .
This disable the Digital OUT !
You can use the SAA7220 as a low Jitter clock by cutting
Pins 6 7 8 !
So it get no Digital Data more ! no Input no Jitter !
Thats makes the Sound more stable , immediately !
can I do the non-os mod at my Philips CD 304 MK2? It has the TDA1541 & SAA7220P/A?
Has anybody a picture from the modded mainboard, because i cant find the pins or can show me in my picture the pins?
Thanks.
Aronier
