Mar-Kel70 in Sweden
Not yet. So far it is just a 1st pass drawing. But if you look at a FonkenPrime vrs a FonkenFloorstander Mk2 you'll get the idea. It could also be used with out the add-on base and a slight port mod as a wall mount (you'd likely have to EQ out the bump at the bottle -- an anti-BSC filter?)
dave
dave
Interesting... Well, as you might know i'm planning on a floorstander with either EL70 or Alpair 10.2 😉
By the way, i sent you an e-mail a couple of days ago but you haven't answered it yet :S
690mm. No FR as no one has built these yet. Performace will be brodly similar to the Mar-Kel, just more dynamic & loudness capability & more whack in the bass.
I need to updat ethe planset with these, which you are entitled to.
dave
Interesting 😉
So it will sound like a "bigger" Mar-Kel70, that's interesting 😉
I still have the problem with my room. I will talk to a guy who works with acoustics (Sounds of Science |) and see if he can help me in anyway to solve my problems.
Can you post a sketch of your room with the furniture
dave
My paint-skills are less than 0. I will take some pictures with the camera and let you see. I'm sorry for the mess, i just can't be arsed to clean it up haha 😛
Well, this thread, more reading and talking to Dave has led me to start down the road of a Twin EL70 floor standing speaker. Hopefully all goes well and I still have all the digits I started with.
I figure that the veneer/finish is going to be the toughest part anyways.
Yeah. I've been thinking of the same thing, but extended bottom containing a front-firing CSS SDX7 to get some more punch in the bass and a maybe a little more depth. I was thinking though, that i guess i want it quite close to the other drivers if i want to XO and 80Hz or higher. I don't know yet how high i would like to XO if i'd like to build one. I also thought of having it in the same box as the EL70 but that would most likely not work i suppose.
I've also been thinking of placing one of the EL70 on top, what would i gain/lose by doing so? If i build, it will probably be 18mm (if it fits on one sheet) or 18mm particle board or MDF. 356€ is a little pricey for the drivers, excluded shipping.
ImageShack Album - 4 images
I know that the wall behind the speaker (from door to window) is 220cm. From wardrobe to window i guess around 310cm. The wall which the window is on is approximately a little less than 400cm. I think the room is a little smaller than 400x400, the wall behind the speaker a little shorter. I sit a little less than 3m away from the speakers.
Again, i apologize for the mess 🙂
You call that a mess? 🙂 Looks clean to me.
Those pictures are from one of the better days. There are days you can't see my huge green carpet beneath all clothes, pillows, books and stuff 😉 Got to get rid of (no, not get rid of but move) that AGA-radio. And i can't forget i got a stack of four 10" subs in my brother's room aswell... Hehe 😉
