Maplin Milleniun 4-20
I tried a Maplin Millenium 4-20 clone build but failed.
These are professionally manufactured clone boards.
A copy of the original article will be provided.
On offer are the two clone PCBs mounted onto a 3mm aluminum chassis.
You get the 2 x PCBs fully populated + the 8 x valve sockets. Nothing else.
The chassis was drilled to accept 2 x Hammond 1650H and a single 250VA toroid, these are NOT supplied.
I'll attach photos of the project. The valves (EL34, EF86 and ECC83) have been removed. The transformers and input / output / mains components have been removed. All you will receive is the chassis with the 2 x PCBs and all the valve sockets.
I don't want to throw it in the rubbish if someone can use it.
These are close clones of the original Maplin PCBs.
If you want the woodwork, please ask.
FREE to a good home, you only pay postage.
