Hi guys,
I'm posting this because it may interest some of you.
Many deals currently available at Acoustic Elegance :
C15.1 15" alum cone woofer for 125$
Quantity Available: 12pcs
Fs: 22Hz
Qts: .46
Qms: 9
Qes: .48
Re: 2.9ohm
Bl: 16.75Tm
Z: 4ohm
Le: 3.3mH
Vas: 130L
Mms: 340g
Cms: .154mm/N
Sd: 771sqcm
Xmax: 23mm
Vd: 3.54L
http://www.aespeakers.com/phpbb2/viewtopic.php?t=765
IB15 for 129$ each or 4x for 400$
Fs: 16Hz
Qms: 6.8
Vas: 439L
Cms: .45mm/N
Mms: 220g
Rms: 3.239
Xmax: 18.5mm
Xmech: 25mm
Sd: 830sqcm
Vd: 3.07L (p-p)
Qes: .78
Re: 5.5ohm
Le: .33mH
Bl:12.49
Pe: 500W
Qts: .7
1WSPL: 86dB
2.83V: 87.3dB
http://www.aespeakers.com/phpbb2/viewtopic.php?t=536
C12.1 12" alum cone woofer for 125$
Quantity Available: 6pcs
Fs: 27Hz
Qts: .5
Qms: 9
Qes: .48
Re: 3ohm
Bl: 16Tm
Z: 4ohm
Le: 2.3mH
Vas: 37L
Mms: 265g
Cms: .13mm/N
Sd: 446sqcm
Xmax: 23mm
Vd: 2.06L
http://www.aespeakers.com/phpbb2/viewtopic.php?t=821
C12.2 Poly cone for 75$
Quantity Available: 29pcs
Fs: 21.5Hz
Qts: .38
Qms: 4.5
Qes: .415
Re: 6.6ohm (in series)
Bl: 18.25Tm
Z: 8ohm (in series)
Le: 2.0mH
Vas: 154L
Mms: 155g
Cms: .35mm/N
Sd: 553sqcm
Xmax: 16mm
Vd: 1.78L
Suggested Power: 150-350W
http://www.aespeakers.com/phpbb2/viewtopic.php?t=832
It seems like very good deals to me, hope it helps someone!
Good day everyone!
Fs: 22Hz
Qts: .46
Qms: 9
Qes: .48
Re: 2.9ohm
Bl: 16.75Tm
Z: 4ohm
Le: 3.3mH
Vas: 130L
Mms: 340g
Cms: .154mm/N
Sd: 771sqcm
Xmax: 23mm
Vd: 3.54L
Fs: 16Hz
Qms: 6.8
Vas: 439L
Cms: .45mm/N
Mms: 220g
Rms: 3.239
Xmax: 18.5mm
Xmech: 25mm
Sd: 830sqcm
Vd: 3.07L (p-p)
Qes: .78
Re: 5.5ohm
Le: .33mH
Bl:12.49
Pe: 500W
Qts: .7
1WSPL: 86dB
2.83V: 87.3dB
Fs: 27Hz
Qts: .5
Qms: 9
Qes: .48
Re: 3ohm
Bl: 16Tm
Z: 4ohm
Le: 2.3mH
Vas: 37L
Mms: 265g
Cms: .13mm/N
Sd: 446sqcm
Xmax: 23mm
Vd: 2.06L
Fs: 21.5Hz
Qts: .38
Qms: 4.5
Qes: .415
Bl: 18.25Tm
Z: 8ohm (in series)
Le: 2.0mH
Vas: 154L
Mms: 155g
Cms: .35mm/N
Sd: 553sqcm
Xmax: 16mm
Vd: 1.78L
Good day everyone!
Does anyone have experience with their drivers in sealed systems?
I'm considering putting (8) 12's into sealed systems in my crawl space, which will also use a Linkwitz transform for compensation to lower the Fs and Qts. I have room to give each driver up to about 75 liters each.
NewbieAudio said:Does anyone have experience with their drivers in sealed systems?
If you're going to do this in the crawlspace can you do an infinite baffle? That would save a lot of trouble building enclosures and you wouldn't have the need for the LT. Check out the Cult IB forum if you aren't familiar with infinite baffles: http://ibsubwoofers.proboards51.com/
Otherwise if you have to go with the enclosures, the C12.2's are really a great value for the price. You'd be able to move a total of 14.24L of air at the rated Xmax.
To calculate maximum SPL at a given frequency based on the displacement capability of the drivers use this formula:
SPL = 20 * Log (Vd * F^2) + 48.4
so say you pick 20hz
SPL = 20 * Log(14.24 *20^2) + 48.4 = 123.5dB half space at 20hz
At 15hz is 118.5dB
Keep in mind this is without figuring room gain into the equation and without figuring decrease in SPL based on the listening position distance from the drivers. It's a good way to compare output capability based on displacement though.
Whether in the enclosures or in an IB, you have the same output capability. You just need a lot more power to move the drivers to the same level in the smaller enclosures.
John
owdi said:Wow. Four of those IB15's in a stereo dipole config would be nice. Any idea what shipping costs?
Dan
The IB15's weigh 19lbs and shipping is standard UPS charge. Depending on where you live that may be anywhere from $9-18 per woofer. We're in Green Bay, WI.
John
I'd love to trade my four AV15s for four of the lambda dipole woofers...
John: Any chance you're going to build up those? I bet they're not going to go for 400 for four or I'd be throwing my credit cards at my computer.
(ok maybe two of the AV15s. I'll keep two for L-T apps.)
Matt
Matt
y8s said:I'd love to trade my four AV15s for four of the lambda dipole woofers...
Matt
Hi Matt,
We just shipped out 4 of the Lambda dipoles last week to a customer. I had never built any of the dipoles before this. I was amazed at the extension with them. Here is what Nick's old site said about the dipoles:
The Lambda Dipole15 Driver is designed specifically for open baffle use with added EQ. This is a high xmax, stiff paper cone, coated and sealed foam surround, 12 spoke aluminum basket, 60oz magnet, dual gold binding posts, and military spec coatings and glues. This a massive *underhung* driver with clean high excursion response to 2Khz. Due to the underhung motor design the power handling is much lower than our other drivers, however these drivers were designed to be used in multiples per channel of 2~8 drivers, hence the power handling is right where it is needed. This driver has some of the best midrange performance of any Lambda product, and there is some interest in using it as a powerful bassmid in a large sealed cabinet, call for more details. Available in dual 8ohm coils only, specs are with both voice coils wired in series.
Full info can be found here.
http://web.archive.org/web/20040307231755/lambdacoustics.com/drivers/DIPOLE15.html
The pricing was $279 each. We're doing the regular TD woofers including the dipoles where you get $100 off if you buy two. Sorry, we cant' do them at the IB price though.
John
y8s said:still a beautiful driver. can't justfy a thousand bucks for four though. I will have to throw some serious pole-shifting EQ at the AV15s and hope for the best.
Matt
Depending on what you're looking to do, the IB15's can work quite well in a dipole application as well. You won't have quite the linearity in the BL curve or the high frequency extension, but used as a woofer they still work well in a dipole. What are you planning on doing with them?
John
John
experimentation mostly.
I've had the four AV15s mounted in two Linkwitz-esque W frames for a while but haven't had the amp channels to do much with a 2x3way active setup so they are languishing as a table.
the AVs were basically an inexpensive route to large volume displacement for a dipole. If the IB15s aren't a quantum leap beyond that, there's no sense in shelling out the money for them, right?
Matt
Matt
No, I really wouldn't bother if that is what you are doing with them. If you're doing a 2x3way system I'd go and get something like the DBX Driverack 260 or the driverack PA. There is a 2in 6 out loudspeaker management system that Behringer makes also, but I haven't tried it. Then you'll have your full Xover, EQ, phase adjustment, time delay, etc all in one system. Then you just need 6 channels of amplification.
John
John
I have a DCX2496 actually. It'll satisfy the testing phase or I can use the multi-channel LspCAD outputs just the same. What I've found works well for amplification (so far) is a cheap 5 or 7.1 integrated amp with a "passthru" multi-channel input. you can run the stereo input to the DCX or sound card and then run the 6 channels (3L and 3R) to the pre-ins on the HT receiver and use it as your multi channel amp and volume control. Problem is, the cheap ones only have 5 useable amplified outputs. Sub doesn't get amplification.
Ultimately I'll convert all the adjustable filters to opamp circuits when I'm satisfied.
I also just built some 41Hz.com tripah amps that should work nicely for this kind of thing.
aaaaaaaaaaand thread drift. thanks for the info on the dipole 15s
matt
Crawl Space sub
Thanks for your advice John E J.
I was away for awhile and couldn't thank you for your reply.
No, I can't do an IB, because I don't want to bother the neighbors. I was originally planning to place the drivers against the wall, and use the openings between the pony joists of my split-level house. That's why I was considering using 12"s - to fit between the 16" centers (actually ~ 14-3/8") of the pony wall joists.
Thanks to your comments, and others, you've made me wonder about using 15" drivers, and making larger manifolds in the crawl space and make tall output openings between these joists, rather than round 12" driver-sized openings into the house.
I'll still need to enclose them, and I do have plenty of space to do that.
Re: Crawl Space sub
If you were to use your entire crawl space as the "enclosure" for an IB you'd notice that the output from the front of the drivers in the room did much more to bother the neighbors than the back wave in the crawl space. Most of the sound from underneath would be stopped from getting out by the ground and foundation, while the front wave will easily travel through walls. If you put the woofers in enclosures, if you will still have sound radiating to all directions. The old subwoofer I had in my duplex not only bothered the neighbors in the other half(although it was fired away from them), but also the neighbors next door and across the street. Oops. Other than doing a dipole which would have nulls at both sides, there isn't much you can do to contain the bass.
Otherwise if you're looking for the best possible sound and can't go IB, the larger the sealed box the better. Fill it with standard fiberglass insulation to help eliminate coloration from the inside of the enclosure.
John
NewbieAudio said:No, I can't do an IB, because I don't want to bother the neighbors. I was originally planning to place the drivers against the wall, and use the openings between the pony joists of my split-level house. That's why I was considering using 12"s - to fit between the 16" centers (actually ~ 14-3/8") of the pony wall joists.
John
- Subwoofers
- Many deals currently at Acoustic Elegance (former Stryke Audio)
