Manual Overide ON switch, Audi Aftermarket
Hi Everyone,
Hopefully in the next few month I will be starting a project to replace the factory stereo setup in an 06 Audi A3 to an aftermarket head unit. As some of you may already know the A3 does not have an auxiliary position on the ignition. I am considering a manual toggle to turn on the radio when the key is off.
Since there will still be an ACC line to the radio I will pull another new constant 12V feed and install diodes to prevent any circuit overloading.
Have any of your done this already? Recommendations on Diodes?
I am currently looking at the SB560 as a low drop diode. It is rated 5A 60V
Thoughts?
I already have a wire harness but it is a pretty primitive one. Since the car’s ignition does not have an ACC position (off-on-start) I think a manual toggle on the dash kit should do just fine. I just wanted to be sure and get the correct Diodes.
