Managing multiple inputs & master level...
Pa Amplifier for home Use
Hi all, just purchased some Mission M34i floor standers, running them off a warrior amp, soon to be a ecler DPA600.
What Im wanting to do is to manage multiple inputs from cd/laptop/Tv and also have control via remote over the master output with out having to manually change the volume pots on the amp, that way I can have the amps stored away out of sight.
What should I be looking for to do this? And ideally a solution that can be picked up secondhand under £100?
Any help would be much appreciated, thanks in advance
Apologies if this is in the wrong section
