Making and onboard bass guitar preamp
I have a passive set up on my bass. 2 soapbar pickups, 2 vol pots and a tone pot. I'd like to add an active preamp with a 3 band EQ with a mid sweep/freq select control. and also with a passive/active switch, so i can switch between the passive ciruit and the active preamp.
So in total there would be 6 knobs and a switch.
Bridge p-up vol (pass)
Neck p-up vol (pass)
Tone (pass)
Pup vol (activ) (push pull p-up select pot)
Treble (active)
Bass (active)
Mid/Mid Sweep (active) (stacked pot)
Active/Passive switch
Does anyone have a schematic for such a set up?
Actually a slight change to the lay out...
Tone - for both Passive and Active
Treble - Active
Mid/Mid Sweep - Stacked pot- Active
Bass - Active
Pickup Blend - Passive and Active
Volume - Passive and Active
Passive/Active Switch
There's a preamp made by John East which is almost exactly like what i want , but i reckon if i can figure out how to make it (with my modifications) it would be alot cheaper. My design is a hybrid of the John East U-Retro 01 Deluxe and the U-Retro 5 Knob deluxe.
John East Preamps
Actually, all you really need to do is add is the 3 band preamp.
Have a squizz at the Aguilar wiring diagrams:
http://www.aguilaramp.com/pdf/support_wiring_obp3.pdf
Look at the diagram with the bypass switch, all you're doing is adding a tone knob before the switch. Its been a while since I looked but you might have some drama finding the right pot to do the mid+mid sweep function, I had looked for one but gave up for an unknown reason.
In fact, using an OBP-3 (or similar 3-band) will save you the drama of tuning your DIY design for the right frequency responses and is a reasonable price (IMO). Have you looked at the Audere? The z-mode is rather tremendous (again, IMO).
in my search for some circuits for help with my preamp design i came across the circuit shown below.
My preamp is going to have
Passive/Active DPDT switch
Tone (pasive and active)
Bass and treble stacked pot (Active)
Mid with mid sweep stacked pot (Active)
Volume
Blend
I plan on taking the pickups into the blend pot then to the input (im going to change out the boost switch in the circuit for a trim pot that will go on the board) then throught to the preamp and EQ.
Where would i add the tone pot and the passive/active switch in this circuit?
How would i alter the "Mid" section to include a mid sweep?
O.K. well I went to radio shack (doh!!) and bought the parts I need to build this. However the T1 calls for a BC548. the closest thing I could find was a PN2907. Do I have anything to consider before wiring this up ?
unohu69
I didn't mean to commandeer this post, just figured since we were on the subject.
Darn wasn't sure if that image was gonna work... so here goes this .....
i was really disappointed in RS quality. +/- 20% WTF is that. how do I get better quality parts ? +/- 10 or even 1 % ?
4 band all sweepable preamp
Suppose I want to make a preamp that all four frequencies act as bells (no shelfs) and have sweepable frequencies, something like:
Bass +-12db 60-600hz
Low mid +-12db 100-1khz
Hi mid +-12db 600-6khz
Hi +-12db 1kz-10khz
Volume
Passive balance (between passive mag pups before pre)
Active Balance (between piezo pups and mag)
Does anyone know a module or can come up with a schematic?
