Hi.
First let me say that I don't believe that cables make a difference in a system. Generally I use whatever I have accumulated over the years, nothing fancy.
I have a double pair of KLH Nines and just bought an Audire Forte to drive them. The preamp is a Krell KRC-3. I've read a few postings here and elsewhere about the need for the cable connected to an Audire Forte to be less than 3 ft long (something about picking up RF and frying itself). My preamp and amp are very close, probably about 1.5 ft will do. So I thought I'd build one. I was thinking about just using a good quality Belden 89259 with decent connectors but saw a few videos/articles about building using cables with 2 shielded conductors and having the shielding connected to the ground cable one the amp size. Question: does it make any difference? Specially in a very short cable?
Elias
Elias
A well-shielded, low-capacitance coax is about the ideal unbalanced cable, and Belden 89259 seems to qualify as such. Shielded 2-conductor cable is primarily aimed at balanced microphones and such; it can be used unbalanced but capacitance would be expected to be higher.
The only parameter I'm not sure of is triboelectric properties of the FEP jacket, a material that is used in triboelectric nanogenerators - then again, so is PVC, as vinylphiles can probably attest (and records aren't usually black for no reason - carbon is conductive). I don't think it would be a huge problem, as the cable wouldn't be subjected to an awful lot of vibration anyway (I don't think we regularly have to run out audio cables next to a running combustion engine or somesuch). The effect of being hit by sound waves might still be measurable, but that's about it.
