Alright electronics gurus here’s the challenge; how do I get the two of these to work together?
http://pinouts.ru/Devices/ipod_pinout.shtml or http://www.ipodlinux.org/Dock_Connector
To work with Clarion 13-pin C-bus http://www.ultrajosh.com/images/Clarion_C-Bus.gif
Any ideas? The goal is to have the dock/recharge for the iPod work with this setup.
You can get a walkman to RCA adaptor from Radio Shack. You have the layout of the changer plug. You will have to leave the changer on the bike. You will have to keep a disk in the changer. You will have to split the cable to get to the left and right signal wire. You will need to use a switch to switch between the changer and the I-pod.
chances are without the changer the radio will not switch to the changer input. It needs to communicate with the changer in order to switch that input.
