Majestic Quantum 1000watts
Is there a schematic reasonably close to this amp. It is in protect mode and finding it tough to figure out.
TL494
1) 4.172
2) 2.317
3) .535
4) 2.363
5) .792
6) .989
7) 0
8) 1.224
9) 0
10) 0
11) 1.224
12) 1.224
13) 2.4
14) 2.4
15) 1.715
16) 2.399
I goes to a transistor. Most of the transistors don't measure correctly in circuit or out. I thought the datasheet says something about a biasing resistor built in, not sure if that is causing the messed up readings.
I will look into that part of it right away. I was just going to bypass the circuit and apply +12 to pin 12.
